Roberto Frieri
da Roberto Frieri » ven apr 05, 2013 8:02 pm
Estratto dalle Release Note:
File support for Leica M Typ 240, M Typ 220 and M-Monochrom (preliminary)"
Per chi ce le ha...
valerio.falzetti
da valerio.falzetti » ven apr 05, 2013 9:40 pm
Buona a sapersi Roberto.
v
Roberto Frieri
da Roberto Frieri » ven mag 03, 2013 11:43 am
GianlucaMonacelli ha scritto:si ma si può usare solo a 64 bit !
Sbaglio?
Apple Mac OS X
•Intel® Core® 2 Duo or better
•4 GB of RAM
•10 GB of free hard disk space
•Calibrated color monitor with 1280 x 800, 24 bit resolution at 96dpi screen ruling
•Mac OS X 10.8.2, 10.7.5, 10.6.8 or later
•Flash is required to view the intro video
•An Internet connection when activating Capture One
Microsoft Windows
•Intel® Core® 2 Duo or better.
•4 GB of RAM
•Windows® 8 64bit, Windows® 7 64bit, Windows Vista® SP2 64bit
•Microsoft® .NET Framework version 4.0 (will be installed if not present)
•A PDF reader is needed to read the Release Notes
Recommended system requirements
Working with high resolution camera systems, doing certain types of adjustments or doing many
things simultaneously may put too much pressure on a minimum requirements system to work
properly. In such cases and to optimize performance, please follow the recommendations below:
• OS X 10.8.3, Mac OS X 10.7.5 or later on Mac
• Use processors with multiple cores, e.g. Intel Core i7TM or better
• Have 16 GB of RAM or more
• Leave plenty of hard disk space free for your images
• A fast hard disk e.g. a Solid State Disk (SSD)
• A fast Graphics card from NVIDIA or AMD, e.g. AMD Radeon 5870, NVIDIA GTX 680 or
Quadro K5000, with updated drivers and a minimum of 2GB RAM
edmondo.dantes
da edmondo.dantes » mer mag 15, 2013 3:31 pm
Ho visto che c'è anche la versione Express, che ha un prezzo molto interessante.
Qualcuno la usa, e nel caso che limitazioni ha rispetto alla PRO. I file raw davrebbe svilupparli egualmente vero?
Ultima domanda: avendo i PLUG-IN della Nik Soft (i vari Silver EFEX ecc..) si possono utlizzare anche all'interno di Capture 1, così come avviene con LR?
Un caro saluto
Edmondo
Roberto Frieri
da Roberto Frieri » mer mag 15, 2013 3:55 pm
edmondo.dantes ha scritto:Ho visto che c'è anche la versione Express, che ha un prezzo molto interessante.
a questo link
http://www.phaseone.com/en/Imaging-Soft ... -7/Pricing trovi una tabella di raffronto tra le due versioni.
A quanto io sappia, non esistono plug-in della Nik Soft per Capture One: ci sono solo per i prodotti Adobe ed Aperture di Apple.
edmondo.dantes
da edmondo.dantes » mer mag 15, 2013 4:32 pm
Roberto Frieri ha scritto:A quanto io sappia, non esistono plug-in della Nik Soft per Capture One: ci sono solo per i prodotti Adobe ed Aperture di Apple.
Bella fregatura. Mi sa che mi tocca rimanere con LR.
Mi sarebbe piaciuto Capture1, perchè sembra avere raggiunto un buon feeling con il sensore X-Trans delle nuove Fuji, ma se per usare i Plug-in devo comunque utilizzare LR, tanto vale...
Un caro saluto
Edmondo
Roberto Frieri
da Roberto Frieri » mer mag 15, 2013 4:43 pm
edmondo.dantes ha scritto:Bella fregatura. Mi sa che mi tocca rimanere con LR.
Capisco; ciò non ti impedisce comunque di scaricare la versione di prova e fare qualche test sui tuoi RAW per vedere la differenza.
